[GRASS-user] g.mlist: order of numbers
Mon Jul 23 23:26:49 EDT 2007
> > > Martin Wegmann wrote:
> > > > I have a script which creates so far n rasters with an analysis
> > > > on different spatial scales.
> > > > Now I want to apply r.series for an analysis of their trend but
> > > > doing it fails because I haven't figured out, how to add all new
> > > > images (name.1, name.2, name.3,...., up to name.n ) to a
> > > > r.series command in the correct order.
> > > > Theoreticall I can merge r.series and g.mlist as shown in the
> > > > help pages but when I run g.mlist the order is: name.1, name.11,
> > > > name.12,....
> > > > It would be no problem adding $GIS_OPT_output.1,
> > > > $GIS_OPT_output.2, ... by hand, but because the number of scales
> > > > differ I had to adept it every time again.
> > > > any hint is appreciated, TIA,
Markus:
> > > probably you have to fill with 0 to get the numbers right, using
> > > something like
> > > echo  "1" | awk '{printf "%03d\n", $1}'
> > > 001
Martin Landa wrote:
> would be better to write script for renaming maps
> name.1 -> name.001, etc.
see this post from last week for exactly that:
  http://grass.itc.it/pipermail/grassuser/2007-July/040423.html
Hamish
