[GRASS-user] dbf File not being Created with v.in.ascii
Ryan Rosario uclamathguy at gmail.com
Tue Jul 24 03:26:12 EDT 2007
Thanks for the suggestions.
I tried that and it did not work. I added an extra column to my data file
called category and exported it to CSV. I then read in the vector using
v.in.ascii input='responseTime.csv' output=response format=point fs=','
skip=1 col='y double, x double, cat int' x=2 y=1 cat=3 --overwrite
I did this both in the GUI and command-line and I also deleted the previous
vector in case there was garbage left over.
v.info response shows no dblinks.
Is there something else I can try?
Ryan
On 7/23/07, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> you are doing nothing wrong, the table is just created if needed. See
> http://www.nabble.com/v.in.ascii-create-a-dbtable-tf3531086.html#a9854181
> Maybe would be good to mention it in man pages of the module.
> Martin
> 2007/7/23, Ryan Rosario <uclamathguy at gmail.com>:
> > I have a vector of data points that I imported from a CSV file (which
> was
> > created with R). When I use v.in.ascii, no DBF file is created. I
> basically
> > need this file so I can assign different colors to data points based on
> the
> > value of the datapoint. The vector is imported correctly, but the DBF is
> not
> > created.
> > v.in.ascii -n input='/Users/ryan/Desktop/Desktop
> > Stuff/ems/responseTime.csv' output=response format=point fs=, skip=1
> > columns='y double, x double, z double' x=2 y=1 z=3 cat=0 --overwrite
> > What am I doing wrong? I have attempted this with both the GUI and the
> > command line and both with and without the quotes as suggested in a
> previous
> > post. DBF files for the other vectors I imported (from ESRI) are showing
> up
> > though.
> > Thanks,
> > Ryan
> > grassuser mailing list
> > grassuser at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grassuser
> Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
<a href="http://www.spreadfirefox.com/?q=affiliates&amp;id=0&amp;t=180"><img
border="0" alt="Get Thunderbird!" title="Get Thunderbird!" src="
http://sfx-images.mozilla.org/affiliates/thunderbird/thunderbird_large.png"/></a>
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070724/e69c0eb4/attachment.html
