[GRASS-user] Water Polygon Issue
Ryan Rosario
uclamathguy at gmail.com
Tue Jul 24 12:42:28 EDT 2007
I believe the file contains closed lines, or that is the way they appear on
the screen.
I was able to color the polygon after using v.type and v.centroids, but now
I have another problem. I am using this water polygon to hide the part of
the Pacific Ocean displayed as part of the county, so I don't want to
display the lines. If I disable "Draw lines" the outline is replaced with a
bunch of small broken line segments. I don't want to display any lines at
all, just a blank polygon that will cover the ocean. Is this where I would
use the v.clean script?
Thanks again,
Ryan
On 7/23/07, M S <mseibel at gmail.com> wrote:
> Does the water polygon display any solid fill (area) color?
> Is the water polygon built for polygons/areas? If not, and they are
> closed lines, you can build them with v.build. If the data is not closed
> lines, and you can afford for the data to move slightly to have GRASS snap
> and close polygons, you can use v.clean.
> On 7/23/07, Ryan Rosario <uclamathguy at gmail.com> wrote:
> > I have a layer called "county" to which I assign a color and the polygon
> > is correctly colored on the display. Unfortunately, this county layer also
> > includes part of the ocean that is regulated by the county. I want to
> > eliminate this by overlaying the water polygon for the county and assigning
> > it white as a background color so only the county land (excluding water)
> > will appear displayed.
> > When I assign a color to the water polygon layer, nothing happens. The
> > layer does not change color. It is as if this layer only defines the outline
> > of the water. Is there a way I can get GRASS to color in this layer so I can
> > achieve what I am looking for?
> > Thanks,
> > Ryan
> > grassuser mailing list
> > grassuser at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grassuser
<a href="http://www.spreadfirefox.com/?q=affiliates&id=0&t=180"><img
border="0" alt="Get Thunderbird!" title="Get Thunderbird!" src="
http://sfx-images.mozilla.org/affiliates/thunderbird/thunderbird_large.png"/></a>
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070724/9d315116/attachment.html
