[GRASS-user] dbf File not being Created with v.in.ascii
StatsJunkie
uclamathguy at gmail.com
Wed Jul 25 01:44:38 EDT 2007
Perhaps I am not understanding what you mean by defining attribute columns.
Below are the first two lines of my csv file.
Latitude,Longitude,Category
34.420757,-119.685126,1
Thanks again,
Ryan
Markus Neteler wrote:
> Can you post the first two lines of you CSV file? Otherwise the problem
> is hard to understand. So far you still don't define any attribute
> columns,
> hence, no DBF (or other table) is generated.
> Markus
> Ryan Rosario wrote on 07/24/2007 09:26 AM:
>> Thanks for the suggestions.
>> I tried that and it did not work. I added an extra column to my data
>> file called category and exported it to CSV. I then read in the vector
>> using
>> v.in.ascii input='responseTime.csv ' output=response format=point
>> fs=',' skip=1 col='y double, x double, cat int' x=2 y=1 cat=3 --overwrite
>> I did this both in the GUI and command-line and I also deleted the
>> previous vector in case there was garbage left over.
>> v.info <http://v.info> response shows no dblinks.
>> Is there something else I can try?
>> Ryan
> ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
> ITC -> since 1 March 2007 Fondazione Bruno Kessler
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
View this message in context: http://www.nabble.com/dbf-File-not-being-Created-with-v.in.ascii-tf4127648.html#a11776634
Sent from the Grass - Users mailing list archive at Nabble.com.
