[GRASS-user] Grass version for grids
Markus Neteler
neteler at itc.it
Wed Jul 25 10:56:48 EDT 2007
Anais Gwendoline Labarre wrote on 07/25/2007 03:00 PM:
> Thanks for your response,
> here is the result of the g.gisenv command :
> ELF 64-bit LSB executable, AMD x86-64,
> version 1 (SYSV), for GNU/Linux 2.4.0,
> dynamically linked (uses shared libs),
> not stripped
> uname -a :
> Linux desktop-nuno 2.6.9-55.0.2.EL.cern #1
> Wed Jun 27 12:27:53 CEST 2007
> i686 i686 i386 GNU/Linux
> For the g.region problem, I modify the WIND and DEFAULT_WIND files and
> there is no longer any error :)
Anaïs,
this indicates that you try to run a binary compiled for 64bit CPU
on a 32bit CPU (i686). This won't work.
You could either download a 32bit GRASS or compile it yourself
(isn't that hard, see
http://grass.gdf-hannover.de/wiki/Compile_and_Install
Markus
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
