[GRASS-user] do not export categories with v.out.ascii
Daniel Victoria daniel.victoria at gmail.com
Wed Jul 25 13:32:39 EDT 2007
Hi Carlos,
Some awk magic might do the trick. Get the ASCII output and filter
with the following
awk -F | '{print $1,$2,$3}'
This will print only columns 1, 2 and 3, as you might have
suspected... the -F sets the column delimiter...
Cheers
Daniel
On 7/25/07, Carlos Guâno Grohmann <carlos.grohmann at gmail.com> wrote:
> Hi.
> I was playing around with v.surf.nnbathy, and I tough it would be nice
> if it could use a vector file as input. The problem is that when
> exporting the vector as ascii to use as input for nnbathy, the file
> has four columns (X,Y,Z,cat), and nnbathy wants a three-column file.
> Can I get a XYZ from vector points without categories or another step
> will be necessary to remove these values from the ascii file?
> cheers
> Carlos
>               Carlos Henrique Grohmann - Guano
>   Visiting Researcher at Kingston University London - UK
>   Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
> Linux User #89721  - carlos dot grohmann at gmail dot com
> _________________
> "Good morning, doctors. I have taken the liberty of removing Windows
> 95 from my hard drive."
> --The winning entry in a "What were HAL's first words" contest judged
> by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
> Can't stop the signal.
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
