[GRASS-user] v.build.polylines
Markus Neteler neteler at itc.it
Thu Jul 26 07:43:50 EDT 2007
M S wrote:
> Is anyone aware of a way to get the results of v.build.polylines but keep
> the attributes and only merge adjacent lines that have the same
> attributes?
> Meaning if one has three lines, where two of them have identical attribute
> values, and one does not, that the two with identical attributes would be
> merged (node removed), and keep the node (and separate line) for the line
> that does not have the same attributes?
> Basically I'd like to merge adjacent lines that only have similar
> attribute
> values.
> Mark
v.build.polylines operates globally. For selective editing, use v.edit
(GRASS 6.3-CVS).
There are the "connect" and the "merge" tool which should exactly do what
you
need (in combination with SQL where statement).
Markus
View this message in context: http://www.nabble.com/v.build.polylines-tf4150762.html#a11808918
Sent from the Grass - Users mailing list archive at Nabble.com.
