[GRASS-user] v.build.polylines
    Markus Neteler
    neteler at itc.it
    Thu Jul 26 09:14:26 EDT 2007
Jarek Jasiewicz wrote:
> Markus Neteler wrote:
>> M S wrote:
>>> Is anyone aware of a way to get the results of v.build.polylines but
>>> keep
>>> the attributes and only merge adjacent lines that have the same
>>> attributes?
>>> Meaning if one has three lines, where two of them have identical
>>> attribute
>>> values, and one does not, that the two with identical attributes would
>>> be
>>> merged (node removed), and keep the node (and separate line) for the
>>> line
>>> that does not have the same attributes?
>>> Basically I'd like to merge adjacent lines that only have similar
>>> attribute
>>> values.
>>> Mark
>> v.build.polylines operates globally. For selective editing, use v.edit
>> (GRASS 6.3-CVS).
>> There are the "connect" and the "merge" tool which should exactly do what
>> you
>> need (in combination with SQL where statement).
>> Markus
> but unfortunatly 'merge' do not work....
It does (for me), I just used it. Please be more specific.
Markus
View this message in context: http://www.nabble.com/v.build.polylines-tf4150762.html#a11810212
Sent from the Grass - Users mailing list archive at Nabble.com.
