[GRASS-user] [GRASSLIST:1208] Re: rrd files and r.in.gdal
Fri Jul 27 10:41:59 EDT 2007
Kirk Wythers wrote:
> On Jul 27, 2007, at 9:13 AM, Frank Warmerdam wrote:
>> Kirk Wythers wrote:
>>> Does r.in.gdal use the rrd files (the ones that build pyramids to
>>> speed up viewing) when importing img files? A bunch of land cover
>>> images that I downloaded came with rrd files (in addition to the
>>> imgs, and I'm trying to figure out if grass uses them).
>> Kirk,
>> r.in.gdal does not exactly import overviews from any of it's input
>> formats.
>> However, GDAL does support overviews in Imagine files (.rrd files) so if
>> you tried to import a big imagine files withoverviews into a low
>> resolution
>> location r.in.gdal would pull from an overview to speed up the import.
> Thanks Frank,
> Does r.in.gdal know to do that automagically (as long as the rrd files
> are in the same directory as the img files)? or is there a flag that
> needs to be set on the import?
Kirk,
It is automatic as is the nature of GDAL for this sort of thing.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
