[GRASS-user] ascii files to import
Kirk Wythers
kwythers at umn.edu
Tue Jul 31 11:34:11 EDT 2007
On Jul 31, 2007, at 9:47 AM, Michael Barton wrote:
> Kirk,
> Your method #1 is straightforward and should go fast. Do you need
> all 100
> columns?
Thanks Michael. Yes, I am afraid that I need all 100, if only because
I am not sure that I won't someday!
> A 3rd way is to make sure that the file has a column to serve as a
> "category/cat" field (integer), save it as a dbf file from Excel
> and use
> v.in.db to create the points. This has the advantage that you can
> name the
> fields more easily. You would then need to reproject it into UTM.
With this approach how would reproject to UTM? I assume you have read
the dbf file into a lat lon location. Right? However, then I would
need to move the data from the lat lon location to the UTM location.
> I'd be a little nervous about trying to convert from latlon to UTM
> within a
> database. GRASS has routines specially designed to do accurate
> reprojection.
This actually works pretty well using the PostGIS extensions on
PostgrSQL (you can use db.connect to point grass to a pg database
rather than the default dbf). There is a very useful tutorial written
by Regina Obe“
http://www.bostongis.com/?content_name=postgis_tut03#30
> Michael
> On 7/30/07 1:59 PM, "Kirk Wythers" <kwythers at umn.edu> wrote:
> __________________________________________
> Michael Barton, Professor of Anthropology
> Director of Graduate Studies
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070731/0a133385/attachment.html
