[GRASS-user] circle surrounding neighbors
Tue Jul 31 14:07:35 EDT 2007
Martin Wegmann wrote:
> > I'm unsure as to whether the test should be < or <=. It's currently
> > <=, but that gives "spikes" (single cells) at the four edges. Using <
> > would give "flats", and would always omit the outermost row/column of
> > pixels. Maybe there should be a +0.5 in the distance calculation?
> then the command works like
> r.neighbors -c input=name output=name method=average size=5
> and the output would be the average of values in a ring of 5x5 around the
> center pixel, wouldn't it?
It's a filled circle (disc), not a "ring". The neighbourhood consists
of all cells whose Euclidean distance from the output cell is <=
size/2:
    for (i = 0; i < ncb.nsize; i++)
	for (j = 0; j < ncb.nsize; j++)
	    ncb.mask[i][j] = sqr(i - ncb.dist) + sqr(j - ncb.dist) <= sqr(ncb.dist);
Note: "<=", not "=".
> then I can drop my r.mapcalc script and close one old wish report related to
> r.le but solved via r.neighbors
> (http://www.intevation.de/rt/webrt?serial_num=2104&display=History) - thanks
> a lot!
The diagram in that post suggests a ring rather than a circle.
I suppose I could add a (e.g.) matrix= option to read an
r.mfilter-style matrix from a file
