[GRASS-user] SQL statement as input for v.surf.rst
    Ulrich Leopold
    uleopold at science.uva.nl
    Fri Jun  1 09:43:16 EDT 2007
On Fri, June 1, 2007 11:23, Markus Neteler wrote:
> On Thu, May 31, 2007 at 11:26:34AM +0200, Ulrich Leopold wrote:
>> Dear all,
>> how would I use an SQL statement correctly as shown in the following
>> command:
>> v.surf.rst input="|SELECT precipitation FROM meteo_stations \
>>                  WHERE date='2005-10-01'" zcolumn=elevation \
>>                  output=prcp_2007-10-01
>> Best regards,
> Ulrich,
> since I am also interested in this, I have now implemented SQL support
> in v.surf.rst (GRASS 6.3-CVS):
Nice job. Thanks a lot for that, Markus.
Ulrich
> Spearfish example (we simulate randomly distributed elevation measures):
> g.region rast=elevation.10m -p
> # random elevation extraction
> r.random elevation.10m vector_output=elevrand n=200
> v.info -c elevrand
> v.db.select elevrand
> # interpolation based on all points
> v.surf.rst elevrand zcol=value elev=elev_full
> r.colors elev_full rast=elevation.10m
> d.rast elev_full
> d.vect elevrand
> # interpolation based on subset of points (only those over 1300m/asl)
> v.surf.rst elevrand zcol=value elev=elev_partial where="value > 1300"
> r.colors elev_partial rast=elevation.10m
> d.rast elev_partial
> d.vect elevrand where="value > 1300"
> Enjoy,
> Markus
> Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
> FBK-irst -  Centro per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18        -       38050 Povo (Trento), Italy
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
