[GRASS-user] help to use r.mapcalc with decimal/binary (modisdata)
Markus Neteler
neteler at itc.it
Mon Jun 4 12:05:33 EDT 2007
On Mon, May 28, 2007 at 02:52:39AM +0100, Glynn Clements wrote:
> First, binary numbers are normally written with the bit 0 (the "units"
> digit) on the right, so "band 1 quality = missing input" would be:
> 1 1 1 1 1 1
> 5 4 3 2 1 0 9 8 7 6 5 4 3 2 1 0
> * * * * * * * * 1 0 1 1 * * * *
> A shell script which uses r.mapcalc to split a QC map given as its
> first argument into separate maps for each field:
> #!/bin/sh
> src=$1
> r.mapcalc <<EOF
> $src.modland = ($src / 1 ) % 4
> $src.cloud = ($src / 4 ) % 4
> $src.band1qual = ($src / 16 ) % 16
> $src.band2qual = ($src / 256 ) % 16
> $src.atmos_corr = ($src / 4096 ) % 2
> $src.adj_corr = ($src / 8192 ) % 2
> $src.diff_orbit = ($src / 16384) % 2
> $src.unused = ($src / 32768) % 2
> EOF
A related proposal: it would be nice to have support for
literal bitpattern strings and a related operator.
[ MODIS LST QA (Land Surface Temperature)
http://www.icess.ucsb.edu/modis/LstUsrGuide/usrguide_1dtil.html#qa
Consider answering to the following question: Give me a map
with Mandatory QA good quality data, or "other quality,
recommend examination of more detailed QA", with Data Flag
at 00 or 01.
Suggestion (written by my colleague Antonio Galea):
"lst_filt = (lstmap ~ [XX XX XX 00]) || (lstmap ~ [XX XX 0X 01])"
- with '~' new bitpattern operator
- [XX ...] literal bitpattern, indicated with []
The ~ operator could be implemented with something like
lstmap ~ [XX XX 01 XX] => ( lstmap.cell & 00001100 ) == 00000100
Like this the application of QA bitpatterns would become more intuitive.
Markus
