[GRASS-user] r.out.arc: small issue
    Hamish
    hamish_nospam at yahoo.com
    Tue Jun  5 00:20:51 EDT 2007
Jarek Jasiewicz wrote:
> Hi
> I just lost few hours importing data from grass to Arc
> for som resons I must it transver as Arc ASCII Grid
> Generally the reason of problems was that grass output ASCII grid as
> LF, but Arc (and some other applications) Requiers CL RF (linux -
> windows problem)
> generally unix2dos utility solve that problem after r.out.arc
I think r.out.arc has been around since the days when Arc/Info commonly
ran on UNIX, and I've never had that problem with the module's output,
so I suspect this is a new bug in Arc. Which version of Arc has the
error? We can add the hint to the help page.
Besides unix2dos, you can work around the problem with this patch:
Index: raster/r.out.arc/main.c
RCS file: /home/grass/grassrepository/grass6/raster/r.out.arc/main.c,v
retrieving revision 2.8
diff -u -r2.8 main.c
--- raster/r.out.arc/main.c     28 Oct 2006 20:33:33 -0000      2.8
+++ raster/r.out.arc/main.c     5 Jun 2007 04:17:35 -0000
@@ -196,11 +196,11 @@
         if(!flag.singleline->answer)
          fprintf (fp, " ");
         else
-          fprintf (fp,"\n");
+          fprintf (fp,"\r\n");
         for (col = 0; col < ncols; col++)
Hamish
