[GRASS-user] r.out.arc: small issue
    Hamish
    hamish_nospam at yahoo.com
    Tue Jun  5 03:18:57 EDT 2007
Jarek wrote:
> >> I just lost few hours importing data from grass to Arc
> >> for som resons I must it transver as Arc ASCII Grid
> >> Generally the reason of problems was that grass output ASCII grid
> >> as LF, but Arc (and some other applications) Requiers CL RF (linux
> >> - windows problem)
> >> generally unix2dos utility solve that problem after r.out.arc
Hamish:
> > I think r.out.arc has been around since the days when Arc/Info
> > commonly ran on UNIX, and I've never had that problem with the
> > module's output, so I suspect this is a new bug in Arc. Which
> > version of Arc has the error? We can add the hint to the help page.
> > Besides unix2dos, you can work around the problem with this patch:
> > Index: raster/r.out.arc/main.c
> > -          fprintf (fp,"\n");
> > +          fprintf (fp,"\r\n");
Jarek:
> It concern ArcView 9.0  with SP2 with TauDEM installed (ie probably
> TauDEM has problem with reading that grid) also problem has TAS GIS -
> ASCII Arc is the only way to import data from GRASS (inspite it has
> more import option)
Ok,
I added the ArcView 9.0 import instructions to the r.out.arc help
page in Jan 2005, and it worked for me then. TauDEM appears to be GPL
open source, so if it's broken anyone can fix it.
r.out.gdal should give you a big pile of common format options:
  http://www.gdal.org/formats_list.html
including another implementation of the Arc GRID format:
  http://www.gdal.org/frmt_various.html#AAIGrid
Hamish
