[GRASS-user] Some suggestions
Carlos "Guâno" Grohmann carlos.grohmann at gmail.com
Tue Jun 5 13:10:47 EDT 2007
I agree. In a single-window environment, you are limited. With
multiple windows, the GRASS way, you have a lot more flexibility.
you can have different maps show side by side (using two displays),
which you can't using a unique window (like Arc), you can leave all
your tools in one window and the map in another, if you have two
screens, and you can have the dialogs for those tools you use more
often (say, r.info, r.mapcalc, etc etc) _opened_ because they are nor
modal, so you don't have to go all through the menus again and again
if you want (need) to do the same task. I just _love_ this.
Also, about the commercial apps, not all of them use the single-window
paradigm. See, for instance ENVI
(http://www.ittvis.com/envi/index.asp) or ERMapper
(http://www.ermapper.com/) which are havy apps (expensive) that use
multiple windows (with ENVI you can get dozens). And no one is
complaining with the companies, because it is good. it works.
Carlos
On 6/5/07, Malte Halbey-Martin <malte at perlomat.de> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> I really like the GUI design of GRASS,
> why? Because I can easy use it on two screens (one for the work, one
> for the displays), can use many monitors two compare maps, etc.
> I see more advantages in the multiple windows GUI and think this is a
> unique selling point.
> Just my two cents
> Malte
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.6 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iD8DBQFGZZXGrf7rTyLkTO4RAhhpAKCrmB1kXMye1b2y4Df+rTA0Vf/LzACgpv5L
> X8saMYKNT57oFUenfim22so=
> =6+Vx
> -----END PGP SIGNATURE-----
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
              Carlos Henrique Grohmann - Guano
  Visiting Researcher at Kingston University London - UK
  Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
Linux User #89721  - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
