[GRASS-user] updated ordinary kriging example using spearfish
Poizot Emmanuel poizot at cnam.fr
Thu Jun 7 02:55:25 EDT 2007
Dylan Beaudette a écrit :
> Hi,
> I have just posted an example of ordinary kriging using the common spearfish
> data. This is based as close as possible to the most current use of GRASS-R
> bindings. Any criticism is appreciated, as this example will be going into
> other materials... and needs to be as up-to-date as possible.
> again this is just an example, not a treatise on geostatistics.
> http://casoilresource.lawr.ucdavis.edu/drupal/node/438
> cheers,
Perhaps I would say that to conducte a geostatistic interpolation a best
as possible, it's missing an anysothropy analysis before choosing to fit
a model to your semi-variogram. Looking to your primary results, it
seems that there is variance gradient North-South, so that perhaps the
variogram have to be construct to take it into account if exists.
Regards
Emmanuel Poizot
Cnam/Intechmer
B.P. 324
50103 Cherbourg Cedex
Phone (Direct) : (00 33)(0)233887342
Fax : (00 33)(0)233887339
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20070607/7569711f/poizot.vcf
