[GRASS-user] problem with r.in.wms
Agustin Diez Castillo
Agustin.Diez at uv.es
Thu Jun 21 06:32:47 EDT 2007
This issue have been discussed on the dev-list without solution as far
as I can say.
see an example:
> same command I got a somewhat different error
# skipped region setting
r.in.wms output=terraserver-drg
mapserver=http://terraserver.microsoft.com/ogcmap6.ashx
layers=DRG format=tiff
> All tiles downloaded successfully
> r.in.gdalwarp -c 'input=/Users/Shared/grassdata/wms_download/
> ERROR 1: TIFFFetchDirectory:/Users/Shared/grassdata/wms_download/
> terraserver-drg_rural_1m_0.tiff: Can not read TIFF directory count
> ERROR 1: TIFFReadDirectory:/Users/Shared/grassdata/wms_download/
> terraserver-drg_rural_1m_0.tiff: Failed to read directory at offset 0
> ERROR 4: `/Users/Shared/grassdata/nc_spm_05/user1/.tmp/
> regadiuet.prearq.uv.es/16540.0warped.geotiff' does not exist in the
> file system,
> and is not recognised as a supported dataset name.
same here, downloaded TIFF contains junk: (903K binary file)
$ tiffinfo wms_download/terraserver-drg__0.tiff
TIFFReadDirectory: wms_download/terraserver-drg__0.tiff: Can not read
TIFF directory
count.
$ gdalinfo wms_download/terraserver-drg__0.tiff
ERROR 1: TIFFReadDirectory:wms_download/terraserver-drg__0.tiff: Can
not read TIFF
directory count
GDALOpen failed - 1
TIFFReadDirectory:wms_download/terraserver-drg__0.tiff: Can not read
TIFF directory
count
So the problem is not new. I'm wondering if somebody can use r.in.wms
in consistent basis. I've only been able to reproduce some of the
manual entries, when trying with other wms servers working in,for
instance, Qqis I got different errors, see above.
> I cannot get r.in.wms into getting me a wms layer imported. The
projection settings match, the layer is avaible for the region. Am I
doing something wrong?
> Input:
> r.in.wms -kp mapserver=http://wms.jpl.nasa.gov/wms.cgi
output=bmng.wms.jul layers=BMNG styles=Jul
> output:
> wms.request -p 'folder=/home/mate/wms_download' 'prefix=wms.bmng.jul'\
> 'mapserver=http://wms.jpl.nasa.gov/wms.cgi' 'layers=BMNG'
'styles=Jul' \
> 'srs=EPSG:4326' 'format=geotiff' 'wmsquery=version=1.1.1'
'maxcols=1024'\
> 'maxrows=1024'
> Calculating tiles
> /usr/lib/grass/etc/r.in.wms//wms.request: 326: SIZE_ARRAY[0]=: not found
> /usr/lib/grass/scripts/r.tileset: 193: declare: not found
> /usr/lib/grass/scripts/r.tileset: 258: Syntax error: Bad for loop
variable
> Requesting 0 tiles!
> wms.download
'requestfile=/home/mate/wms_download/wms.bmng.jul_.wget'
'wgetoptions=-c -t 5 --user-agent=MSIE5.5'
> Downloading tiles
> r.in.gdalwarp -c -k -p 'output=wms.bmng.jul' 'method=nearest'
's_srs=EPSG:4326'
> ERROR: Required parameter <input> not set:
> (Raster file or files to be imported. If multiple files are
specified they will be patched together.).
> Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
> Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
