[GRASS-user] problem installing grass 6.2.1
Jorge Echeverri jorge.echeverri at Stein.de
Thu Jun 21 07:42:03 EDT 2007
Hi everybody,
I had to reinstall suse 10.2 (i586) running on AMD 32-bit arquitecture.
Following instrucions by Otto Dessau on:
http://download.qgis.org/qgis/suse/10.2/
I could install geos-2.2.3-1suse10.2.i586.rpm and
proj-4.5.0-2suse10.2.i586.rpm but when installing
gdal-1.4.1-0suse10.2.i586.rpm it complains about not having
libodbcinst.so.1
For some reason I am not able download from several web sites I found.
Could somebody provide me with this file?
Thanks
Jorge
Am Donnerstag, den 21.06.2007, 12:39 +0200 schrieb
grassuser-request at grass.itc.it:
> Send grassuser mailing list submissions to
> 	grassuser at grass.itc.it
> To subscribe or unsubscribe via the World Wide Web, visit
> 	http://grass.itc.it/mailman/listinfo/grassuser
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	grassuser-owner at grass.itc.it
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of grassuser digest..."
> Today's Topics:
>    1. Re: g?or?f?recement ? partir d'une carte d?ja g?or?f?renc?e
>       (Mamadou Diallo)
>    2. d.zoom (Camilo Alcantara)
>    3. problem with v.patch (Leonardo Lami)
>    4. problem with r.in.wms (Maximilian Krambach)
>    5. Re: problem with r.in.wms (Ivan Shmakov)
>    6. Re: g?or?f?recement ? partir d'une carte d?ja g?or?f?renc?e
>       (Moritz Lennert)
>    7. Re: problem with r.in.wms (Agustin Diez Castillo)
> Message: 1
> Date: Wed, 20 Jun 2007 16:55:22 +0200
> From: "Mamadou Diallo" <Mamadou.Diallo at unizar.es>
> Subject: Re: [GRASS-user] g?or?f?recement ? partir d'une carte d?ja
> 	g?or?f?renc?e
> To: "beryouni khadija" <beryouni_khadija at yahoo.fr>,	"list grass user"
> 	<grassuser at grass.itc.it>
> Message-ID: <002801c7b34b$0767c9f0$371dd29b at Mamadou>
> Content-Type: text/plain; charset="iso-8859-1"
> Slt
> Il faut voir si a peut t'aider:
> 3 Gocoder une carte scanne (4 points d'angle) : carte topographique au 1:24000
> GRASS peut servir  gorfrencer des couches livres sans rfrencement (par exemple, si elles ont t scannes) en dfinissant des points d'amer au sol. Cette carte scanne devra tre importe dans un Secteur XY sans projection dfinie. Ce secteur peut tre cr automatiquement en utilisant la commande r.in.gdal  partir d'un Secteur quelconque. En utilisant le paramtre "Secteur", la commande ne se contentera pas seulement d'importer la couche, mais galement de l'inscrire dans un nouveau Secteur (voir partie 3.1.5). Ensuite, il vous faut relancer GRASS avec le nouveau Secteur XY contenant la carte scanne. Nous allons maintenant donner les grandes lignes de la procdure sans trop s'attarder sur le dtail des oprations :
>   a.. Le couche scanne doit tre intgre  un groupe d'images (i.group; mme s'il s'agit d'une couche isole).
>   b.. Le groupe est associ  un Secteur de destination (i.target).
>   c.. L'utilisateur ouvre un moniteur GRASS et place  l'aide de la souris des points d'amer (i.points ou i.vpoints). La couche non rfrence est charge dans la partie gauche de l'affichage graphique, tandis que la couche rfrence est charge dans la partie droite. Pour une couche qui ne prsente pas de dformation gomtrique, quatre points  chacun des angles devrait suffire.
>   d.. La couche non-gorfrence est recale dans le Secteur de rfrence. (i.rectify). La complexit polynomiale pour un recalage utilisant 4 points est d'ordre 1.
> Une fois le recalage termin, vous devez quitter GRASS et le relancer avec le Secteur de rfrence. L'opration peut  prsent tre valide.
> Au revoir tu pourras aussi voir le logiciel franais geoconcept
>   ----- Original Message -----
>   From: beryouni khadija
>   To: list grass user
>   Sent: Wednesday, June 20, 2007 3:22 PM
>   Subject: [GRASS-user] gorfrecement  partir d'une carte dja gorfrence
>   bonjour,
>   j'ai une question concernant le gorfrecement  partir d'une carte dja gorfrence: comment dois-je faire pour afficher dans un moniteur graphique  la fois la carte gorfrence et photographie arienne que je veux caller? je vous cris la procdure que j'ai suivi et vous me dites SVP ce que je dois modifier ou ajouter:
>   r.in.gdal pour importer la photo aerienne
>   i.group pour cer un groupe et choisir ses rasters
>   i.target
>   d.mon start=x0
>   i.points
>   j'ai fait a pour le premire fois en choisissant la photo aerienne seule ds les raster du gooupe (i.group) donc dans le moniteur graphique j'avais seulement la photo aerienne, j'ai refait le travail en choisissant la photo et la carte dans le groupe (i.group) donc j'avais les deux dans le moniteur graphique mais je ne pouvait afficher qu'une seule alors que je veux les deux affiches pour que je puisse choisir les points de callage.
>   merci d'avance
>   Ne gardez plus qu'une seule adresse mail ! Copiez vos mails vers Yahoo! Mail
>   _______________________________________________
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: http://grass.itc.it/pipermail/grassuser/attachments/20070620/fb282ce4/attachment-0001.html
> Message: 2
> Date: Wed, 20 Jun 2007 20:38:17 -0500
> From: "Camilo Alcantara" <camilo at pcbiol.posgrado.unam.mx>
> Subject: [GRASS-user] d.zoom
> To: grassuser at grass.itc.it
> Message-ID:
> 	<89671eb50706201838i250ab813s662290190e2aaf60 at mail.gmail.com>
> Hi
> I would like to report a small bug in d.zoom. While panning, with the
> command "d.zoom -p" over any image on a regular monitor (e.g x1), the region
> is "shrinking" by one pixel on each side of the window. It is not a big deal
> when panning a map once or two times, but if panning is done several times
> to explore at a larger scale a map it could be annoying.
> Best
> Pedro Camilo Alcntara Concepcin
> Department of Forest Ecology and Management
> Rm. 120 Russell Labs
> 1630 Linden Dr.
> Madison WI 53706-1598
> Phone +1/608/265-9219
> http:/silvis.forest.wisc.edu
> URL: http://grass.itc.it/pipermail/grassuser/attachments/20070620/d7e90e03/attachment-0001.html
> Message: 3
> Date: Thu, 21 Jun 2007 09:58:45 +0200
> From: Leonardo Lami <lami at faunalia.it>
> Subject: [GRASS-user] problem with v.patch
> To: GRASS-user <grassuser at grass.itc.it>
> Message-ID: <467A2FB5.2050301 at faunalia.it>
> Content-Type: text/plain; charset=ISO-8859-15
> Hi all,
> I seen a bug in v.patch. If  I use two or more simple vectors it works
> well but if I use I see big problem in the topology of the output. This
> in 6.2.1 and in 6.3 version.
> I add a link to a dataset with 2 vectors to make testing.
> www.faunalia.it/download/vpatch.tar.gz
> Thank you
> Leonardo
> Message: 4
> Date: Thu, 21 Jun 2007 11:01:50 +0200
> From: "Maximilian Krambach" <Maximilian.Krambach at gmx.de>
> Subject: [GRASS-user] problem with r.in.wms
> Message-ID: <20070621090150.101430 at gmx.net>
> I cannot get r.in.wms into getting me a wms layer imported. The projection settings match, the layer is avaible for the region. Am I doing something wrong?
> Input:
> r.in.wms -kp  mapserver=http://wms.jpl.nasa.gov/wms.cgi output=bmng.wms.jul layers=BMNG styles=Jul
> output:
> wms.request  -p 'folder=/home/mate/wms_download' 'prefix=wms.bmng.jul'\
> 'mapserver=http://wms.jpl.nasa.gov/wms.cgi' 'layers=BMNG' 'styles=Jul' \
> 'srs=EPSG:4326' 'format=geotiff' 'wmsquery=version=1.1.1' 'maxcols=1024'\
> 'maxrows=1024'
> Calculating tiles
> /usr/lib/grass/etc/r.in.wms//wms.request: 326: SIZE_ARRAY[0]=: not found
> /usr/lib/grass/scripts/r.tileset: 193: declare: not found
> /usr/lib/grass/scripts/r.tileset: 258: Syntax error: Bad for loop variable
> Requesting 0 tiles!
> wms.download  'requestfile=/home/mate/wms_download/wms.bmng.jul_.wget' 'wgetoptions=-c -t 5 --user-agent=MSIE5.5'
> Downloading tiles
> All tiles downloaded successfully
> r.in.gdalwarp  -c -k -p 'output=wms.bmng.jul' 'method=nearest' 's_srs=EPSG:4326'
> ERROR: Required parameter <input> not set:
>     (Raster file or files to be imported. If multiple files are specified they will be patched together.).
> Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
> Ideal fr Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
> Message: 5
> Date: Thu, 21 Jun 2007 16:16:28 +0700
> From: "Ivan Shmakov" <oneingray at gmail.com>
> Subject: Re: [GRASS-user] problem with r.in.wms
> Message-ID:
> 	<b1e3a35f0706210216p271090d1jcb8da6651f35601e at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> >>>>> "MK" == Maximilian Krambach <Maximilian.Krambach at gmx.de> writes:
>         Looks like a sh/dash/bash problem?  What's the first line of
>         /usr/lib/grass/scripts/r.tileset?  E. g.:
> $ head -n1 /usr/lib/grass/scripts/r.tileset
> Message: 6
> Date: Thu, 21 Jun 2007 11:20:22 +0200
> From: Moritz Lennert <mlennert at club.worldonline.be>
> 	g?or?f?renc?e
> To: Mamadou Diallo <Mamadou.Diallo at unizar.es>
> Cc: list grass user <grassuser at grass.itc.it>,	beryouni khadija
> Message-ID: <467A42D6.4080905 at club.worldonline.be>
> [responding in French, inviting the senders to use the French-speaking
> mailing list]
> Comme dj dit prcdemment  Khadija: toutes les listes de GRASS
> (grass-user, wingrass, grass-dev) sont des listes anglophones. Y poster
> des messages en franais est fortement dcourag !
> Si vous voulez discuter des questions concernant GRASS en franais,
> veuillez utiliser la liste francophone qui est l pour a:
> http://www.linux-nantes.fr.eu.org/mailman/listinfo/grass-fr
> Merci !
> Moritz
> Mamadou Diallo wrote:
> > Slt
> > <http://www.gdf-hannover.de/lit_html/nutshell_v10_fr/node15.html#sec:auto_generate_location>).
> >     * Le couche scanne doit tre intgre  un groupe d'images
> >     * Le groupe est associ  un Secteur de destination (i.target).
> >     * L'utilisateur ouvre un moniteur GRASS et place  l'aide de la
> >     * La couche non-gorfrence est recale dans le Secteur de
> >     *From:* beryouni khadija <mailto:beryouni_khadija at yahoo.fr>
> >     *To:* list grass user <mailto:grassuser at grass.itc.it>
> >     *Sent:* Wednesday, June 20, 2007 3:22 PM
> >     *Subject:* [GRASS-user] gorfrecement  partir d'une carte dja
> >     gorfrence
> >     bonjour,
> >     i.target
> >     d.mon start=x0
> >     i.points
> >     merci d'avance
> >     <http://www.trueswitch.com/yahoo-fr/> vers Yahoo! Mail
> Message: 7
> Date: Thu, 21 Jun 2007 12:32:47 +0200 (CEST)
> From: "Agustin Diez Castillo"<Agustin.Diez at uv.es>
> To: "Maximilian Krambach" <Maximilian.Krambach at gmx.de>
> Cc: grassuser at grass.itc.it
> Message-ID: <2975192826adiez at uv.es>
> Content-Type: text/plain;	charset="ISO-8859-1"
> This issue have been discussed on the dev-list without solution as far
> as I can say.
> see an example:
> > same command I got a somewhat different error
> # skipped region setting
> r.in.wms output=terraserver-drg
> mapserver=http://terraserver.microsoft.com/ogcmap6.ashx
> layers=DRG  format=tiff
> > r.in.gdalwarp  -c 'input=/Users/Shared/grassdata/wms_download/
> > ERROR 1: TIFFFetchDirectory:/Users/Shared/grassdata/wms_download/
> > terraserver-drg_rural_1m_0.tiff: Can not read TIFF directory count
> > ERROR 1: TIFFReadDirectory:/Users/Shared/grassdata/wms_download/
> > terraserver-drg_rural_1m_0.tiff: Failed to read directory at offset 0
> > ERROR 4: `/Users/Shared/grassdata/nc_spm_05/user1/.tmp/
> > regadiuet.prearq.uv.es/16540.0warped.geotiff' does not exist in the
> > file system,
> > and is not recognised as a supported dataset name.
> same here, downloaded TIFF contains junk:  (903K binary file)
> $ tiffinfo wms_download/terraserver-drg__0.tiff
> TIFFReadDirectory: wms_download/terraserver-drg__0.tiff: Can not read
> TIFF directory
> count.
> $ gdalinfo wms_download/terraserver-drg__0.tiff
> ERROR 1: TIFFReadDirectory:wms_download/terraserver-drg__0.tiff: Can
> not read TIFF
> directory count
> GDALOpen failed - 1
> TIFFReadDirectory:wms_download/terraserver-drg__0.tiff: Can not read
> TIFF directory
> count
> So the problem is not new. I'm wondering if somebody can use r.in.wms
> in consistent basis. I've only been able to reproduce some of the
> manual entries, when trying with other wms servers working in,for
> instance, Qqis I got different errors, see above.
> > Input:
> > output:
> 'styles=Jul' \
> 'maxcols=1024'\
> > 'maxrows=1024'
> > Calculating tiles
> variable
> > Requesting 0 tiles!
> > wms.download
> > Downloading tiles
> 's_srs=EPSG:4326'
> End of grassuser Digest, Vol 14, Issue 21
