[GRASS-user] problem with r.in.wms
WolfgangZ
wollez at gmx.net
Thu Jun 21 16:21:18 EDT 2007
Sorry if I go off topic, but wouldn't be r.in.wms a good example to re
write it (almost) fully in python? So you could get rid of many
dependencies and make grass more portable. I did not completely
understood in the scripts the use of r.tileset and gdalwarp but I had
only a short look at the script till now. It is only a suggestion, and
there is still a lot to learn for me regarding programming at all and
programming for grass in specific.
Ivan Shmakov schrieb:
>>>>>> "MK" == Maximilian Krambach <Maximilian.Krambach at gmx.de> writes:
> >> Looks like a sh/dash/bash problem? What's the first line of
> >> /usr/lib/grass/scripts/r.tileset? E. g.:
> >> $ head -n1 /usr/lib/grass/scripts/r.tileset
> MK> First line is #!/bin/sh
> I guess it needs to be changed to #!/bin/bash (and you're to
> have Bash installed, of course.)
> MK> 193 is part of
> MK> # purpose: lookup values in passed by reference arrays
> MK> declare -f LookupP # Function "Pointer"
> There's a `declare' command in Bash, but not in POSIX shell, nor
> in Dash.
> MK> btw: installation is 6.2.1 from Jachym's ubuntu repository
> MK> (les-ejk.cz)
> IIRC, Ubuntu uses Dash for /bin/sh by default.
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
