[GRASS-user] v.lrs.where users wanted
lami at faunalia.it lami at faunalia.it
Mon Jun 25 05:48:54 EDT 2007
Greatings!
I will make other tests on the modules in the next days!
Hopefully
Leonardo
> Hi,
> I finally got my LRS working (playing with the busroute in
> the new NC dataset). The trick is to have the route built
> as polyline (v.build.polylines), otherwise you will get
> crazy to figure out the milepost order.
> - documentation updated
> - v.lrs.label now works (SQL fix in CVS)
> - v.lrs.where:
>    Then I tested v.lrs.where and discovered that the "offset"
>    was reported incorrectly. I have fixed it in CVS but would
>    like to ask LRS users to test if it still works ok for you.
>    Please let me know.
> - v.lrs.segment: still to test, seems to do something
> Related question: how to add a new milepost into an existing
> LRS?
> Markus
> Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
> FBK-irst -  Centro per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18        -       38050 Povo (Trento), Italy
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
