[GRASS-user] problem with v.patch
Leonardo Lami
lami at faunalia.it
Tue Jun 26 06:58:02 EDT 2007
http://www.faunalia.it/download/vpatch.tar.gz
At this link you can download a location with the two vectors.
Thanks very much for your patient.
Leonardo
Maciej Sieczka ha scritto:
> Leonardo Lami wrote:
>> Sorry for my persistence but I don't understand what does "if the 2
>> vectors are not compatible in terms of geometry" mind?
> I mean if the 2 vectors "fit each other" - common vertices at locations
> where you want to connect them, common boundaries.
>> The two vector are area geometry and topologically correct with same
>> external boundaries of one collinear with same external boundaries of
>> the other.
> OK, so you say they should fit each other. Please put a location
> containing both vectors so I can see what's wrong.
> Maciek
