[GRASS-user] v.db.addclo + sqlite
Markus Neteler
neteler at itc.it
Wed Jun 27 03:37:21 EDT 2007
Daniel,
Daniel Victoria wrote:
> Hi all,
> I'm using GRASS 6.2.1 from Jachym Ubuntu repositories and v.db.addcol
> with sqlite is behaving strangely.
> First I created some random points (v.random) and created a table for
> it in a sqlite database (v.db.addtable pontos). The table with the cat
> col gets created OK. Now I want to sample some rasters with the points
> so I first create a new column (v.db.addcol map=pontos column="teste
> INT") and I get the following:
> GRASS 6.2.1 (amazon):~/modis > v.db.addcol map=pontos column="teste INT"
> /usr/lib/grass/scripts/v.db.addcol: 96: let: not found
That's the problem: "let not found". It was a bash-ism (shell script bug)
which
was fixed later. You can simply grab v.db.addcol from 6.2.2 (which we should
release
asap, or take the release candidate which works apparently fine).
Markus
View this message in context: http://www.nabble.com/v.db.addclo-%2B-sqlite-tf3985632.html#a11319833
Sent from the Grass - Users mailing list archive at Nabble.com.
