[GRASS-user] disappearing gis.m
Stuart Edwards sedwards2 at cinci.rr.com
Sat Mar 3 17:18:45 EST 2007
Hi
Just updated to 6.2 using Lorenzo's binaries and now have the
disappearing gis.m manager syndrome -- saw some correspondence about
this in January, but not for OSX. Everything works fine when the
startup is X11, but in OSX or X11 OSX, the following errors occur:
GRASS 6.2.1 (tinatown):~ > Error in startup script: bad variable name
"coords(1)": upvar won't create a scalar variable that looks like an
array element
     while executing
"global coords($mon)"
     (procedure "MapCanvas::pointer" line 5)
     invoked from within
"MapCanvas::pointer $mon"
     (procedure "MapCanvas::create" line 226)
     invoked from within
"MapCanvas::create"
     (procedure "Gm::startmon" line 11)
     invoked from within
"Gm::startmon"
     (procedure "Gm::create" line 69)
     invoked from within
"Gm::create"
     (procedure "main" line 30)
     invoked from within
"main $argc $argv"
     (file "/Applications/GrassGIS/Grass6.app/Contents/Resources/
grass-6.2.1/etc/gm/gm.tcl" line 521)
Also tried the 6.3 cvs with the same result.
OSX 10.4.8 on Intel Xeon 2x2.66
Any suggestions much appreciated.
Stu
