[GRASS-user] The print button in Map Display
Moritz Lennert mlennert at club.worldonline.be
Mon Mar 5 13:14:20 EST 2007
On 05/03/07 18:42, Aldo Clerici wrote:
> Dear GRASSusers,
> I'm having strange results with the print button in Map Display. More
> precisely i'm not able to print the entire picture displayed in the Map
> Display. I changed the 'Preset paper type' and the 'Custom paper size' in
> the panel but the resulting printed map shows dimensions that seem not
> related to the selected values. That happens with GRASS6.2 and 6.3 whereas
> the same function works well in GRASS6.0. Did anyboy face with the same
> problem?
Maybe the print dialog uses the current region settings, which might not
be the same as the zoom level in the Map display.
Try "Set current region to map display" in the zoom drop-down menu of
the map display.
Moritz
