[GRASS-user] Spatial Statistics
Dr. Manuel Seeger
seeger at uni-trier.de
Wed Mar 7 12:38:09 EST 2007
Markus Neteler schrieb:
> Manuel,
> v.rast.stats is your friend:
> v.rast.stats - Calculates univariate statistics from a GRASS raster map based on vector objects
> http://grass.itc.it/grass63/manuals/html63_user/v.rast.stats.html
> Hope this helps,
> Markus
Thank you!
It works.
But not really clean.
if I try to let the module add the colums by itself, it creates an eroor
after the first column, retrying it goes on and stops at the second etc.
so I have to repeat the procedure. The problem is, that on this way, it
leaves temporary raster files within my mapset in use for every step...
Please excuse, but I dind not copy the error echo.
Perhaps someone may reproduce it?
Again, thanks a lot!
Manuel
Dr. Manuel Seeger
Wiss. Assistent Scientific Assistant
Physische Geographie Dpt. of Physical Geography
FB VI - Geographie/Geowissenschaften Geography/Geosciences
Universität Trier University of Trier
D - 54286 Trier
Tel.: +49-651-201 4557
Fax: +49-651-201 3976
Web: http://www.uni-trier.de/uni/fb6/geographie/mitarbeiter/Seeger/
