[GRASS-user] Spatial Statistics
    Slover, Kevin
    kslover at Dewberry.com
    Wed Mar  7 14:50:40 EST 2007
My $.02
I have used the v.rast.stats command many times with much success.
Though, I have to admit, I still haven't graduated to GRASS 6.X yet.  I
used 5.4 and it worked with no problems whatsoever.
Kevin Slover
Coastal / GIS Specialist
2872 Woodcock Blvd Suite 230
Atlanta GA 30341
(P) 678-530-0022
(F) 678-530-0044
-----Original Message-----
[mailto:grassuser-bounces at grass.itc.it] On Behalf Of Markus Neteler
Sent: Wednesday, March 07, 2007 2:44 PM
To: GRASSLIST
Subject: Re: [GRASS-user] Spatial Statistics
On Wed, Mar 07, 2007 at 06:38:09PM +0100, Dr. Manuel Seeger wrote:
> Markus Neteler schrieb:
> >Manuel,
> >v.rast.stats is your friend:
> > v.rast.stats - Calculates univariate statistics from a GRASS raster
map
> > based on vector objects
> > http://grass.itc.it/grass63/manuals/html63_user/v.rast.stats.html
> >Hope this helps,
> >Markus
> Thank you!
> It works.
> But not really clean.
> if I try to let the module add the colums by itself, it creates an
eroor
> after the first column, retrying it goes on and stops at the second
etc.
Which error actually?
> so I have to repeat the procedure. The problem is, that on this way,
it
> leaves temporary raster files within my mapset in use for every
step...
This should not happen of course.
I see that an empty file is left behind, will check.
> Please excuse, but I dind not copy the error echo.
> Perhaps someone may reproduce it?
I just tried the example from the manual page, no problem.
Please tell us
- which error
- which GRASS version
- which operating system
Markus
> Again, thanks a lot!
> Manuel
> Dr. Manuel Seeger
> Wiss. Assistent 			Scientific Assistant
> Physische Geographie 			Dpt. of Physical Geography
> FB VI - Geographie/Geowissenschaften 	Geography/Geosciences
> Universit?t Trier			University of Trier
> D - 54286 Trier
> Tel.:	+49-651-201 4557
> Fax:	+49-651-201 3976
> Web:	http://www.uni-trier.de/uni/fb6/geographie/mitarbeiter/Seeger/
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Visit Dewberry's website at www.dewberry.com
This email transmission may contain confidential or privileged information. If you receive this email message in error, notify the sender by email and delete the email without reading, copying or disclosing the email contents. The unauthorized use or dissemination of any confidential or privileged information contained in this email is prohibited.  If you are not the intended recipient and intentionally intercept or forward this message to someone else, you may be subject to criminal and/or civil penalties.  See 18 U.S.C. 2511 et seq.
