[GRASS-user] long run time with r.sunmask
Hamish
hamish_nospam at yahoo.com
Thu Mar 8 17:17:32 EST 2007
Markus Neteler wrote:
> Dylan Beaudette wrote on 03/08/2007 02:25 AM:
> > Hi everyone,
> > using the latest CVS, I noticed that running r.sunmaks on a
> > relatively small region (300x300 cells) took a very long time to
> > run (about 15 minutes). I am using a DEM for the location and
> > specifying the time of day, and day of the year. I used the
> > following command:
> > r.sunmask elev=elev_meters out=shadows_afternoon timezone=-8
> > year=2007 month=3 day=31 hour=16 minute=00 second=00
> > Any idea on why this would take so long?
> ... because of r.sunmask slowliness...
> For a fast solution, use r.sun instead.
> Shadow maps
> A map of shadows can be extracted from the solar incidence
> angle map (incidout). Areas with
> zero values are shadowed. The -s flag has to be used.
any idea if this is because of the (better) SOLPOS algorithm r.sunmask
uses, or is it just inefficient structure in the r.sunmask module?
ie if/when r.sun is updated to use SOLPOS, can we expect a big slowdown
in r.sun run times?
Hamish
