[GRASS-user] Compiling grass 6.2.1: i.class error
Sean Fulton seanasy at gmail.com
Fri Mar 9 11:46:18 EST 2007
On 2007-03-05 20:45:41 -0500, Glynn Clements <glynn at gclements.plus.com> said:
> Sean Fulton wrote:
>> I'm trying to compile 6.2.1 on Mac OS X 10.4.8.  I get an undefined
>> symbol (_I_vask_subgroup_old) error compliling i.class.
>> Can anyone point me in the right direction for resolving this? Output is below.
> How/where did you get the source code? The file containing that
> function (lib/imagery/vask_group.c) has been removed from the CVS
> trunk, but is still present in the 6.2 branch.
> Also, if you have a 6.3 version installed such that the linker will
> find its libraries, that could potentially cause this problem.
So, are you recommending using the CVS version? (I'd rather not)
Is there any clue to what the problem is?
Thanks,
	Sean
