[GRASS-user] v.in.ogr: shape files import trouble
Pierluigi De Rosa
pierluigi.derosa at gfosservices.it
Sun Mar 11 15:30:06 EDT 2007
i think your file is not topologically correct...
Be sure about your data! More often the shape file have this problem if
they have nodes or boundaries not rightly overlapped.
Try to use tha snap threshold feature in v.in.ogr combined with area
option...
Cheers
Pierlugi De Rosa
GfoServices S.A.
> Hi you all
> I am facing with a shape files import problem.
> I got a shape file, polygons in it got areas, but when I push them into
> grass using v.in.ogr several polygons lost their area and the only thing I
> get it's a centroid, no boundary, no lines but simply a centroid.
> QGis currently shows this shape correctly, so every polygon got his areas.
> Same problem, if any and not my fault, occurs with grass6.2cvs and
> grass6.3cvs, debian testing OS.
> Any suggestion?
> thanx
> raffaele
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
