[GRASS-user] v.in.ogr: shape files import trouble
Raffaele Morelli
raffaele.morelli at gmail.com
Mon Mar 12 06:54:41 EDT 2007
> how does it look if you skip cleaning the data?
Same problem -c doesn't affect resulting vector.
topology is not guaranteed then, but if the data is only for looking at
> it might be ok.
> v.in.ogr -c
tried with min_area and snap option, also imported without cleaning and
later applying v.clean with several tools/paramenter settings.
I faced this problem some time ago* *when using v.patch (Maciej should
remember about that) from those same files.
I guessed it was an overlapping shapes problem or, as Pierluigi suggests, an
incorrect topology issue.
But, how can I get data displayed like in QGis? or can I at all?
raffaele
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070312/520fcf53/attachment.html
