[GRASS-user] r3.in.v5d works? examples?
mespana at ugr.es mespana at ugr.es
Tue Mar 13 11:47:54 EDT 2007
Dear grassuser,
I'm trying to use the r3.in.v5d module, to load a MM5 (atmospheric
modelling) output from vis5d. I read at the manual pages that the command
imports only one variable and one step time. Ok, but after that, I cannot
visualize with Nviz the resulting g3d map.
I've followed the next sequence of actions at Grass shell:
r3.in.v5d input=vis5dmap.file output=SOC_mm5
g.region rast3d=SOC_mm5
nviz -q
Load volumes visualization panel.
choose SOC_mm5 as new volume
change attribute threshold with constants within the range of levels
I can't see nothing.
Maybe I'm doing something wrong. I trained with the tutorial from
Slovakia3D data set, and I've got the correct results.
I've also tried to import vis5d example files, like hole.v5d or LAMPS.v5d,
but it didn't go on.
I wonder if anyone can help me in this question as experimented grass
user, because I was looking for articles, manuals o similar using this
command, but I didn't find anything.
Thanks for your attention.
Miriam
<>   Miriam España Acebal
<>   Ingeniera en Informatica / Computer Science Engineer
<>   Departamento de Fisica Aplicada / Applied Physics Department
<>   G. I. Fisica Atmosferica / Atmospheric Physics Research Group
<>   Universidad de Granada / University of Granada
<>   España / Spain
<>   mespana at ugr.es
