[GRASS-user] grass63 command fails after cvs update - solved
Martin Wegmann
wegmann at biozentrum.uni-wuerzburg.de
Wed Mar 14 09:49:04 EDT 2007
thanks, now it works again, Martin
On Wednesday 14 March 2007 14:13, Glynn Clements wrote:
> Martin Wegmann wrote:
> > to check if my update routine produced an error, I changed the directory
> > and
> > did a fresh cvs download but same error occurs:
> > >grass63
> > /usr/local/bin/grass63: line
> > 27:
> > /home/baliola/software/grass/grass63/grass6/NONE/grass-6.3.cvs/etc/Init.s
> >h: No such file or directory
> > /usr/local/bin/grass63: line 27:
> > exec:
> >h: cannot execute: No such file or directory
> > why is GRASS looking in my temporary software installation directory? It
> > should be /usr/local/..., shouldn't it?
> > any idea what I did wrong? Martin
> I made a mistake in a recent change to the configure script. It has
> since been fixed in CVS, or you can use --prefix=/usr/local to avoid
> the problem (if you don't specify a --prefix option, ${prefix}
> defaults to NONE; configure changes this to the default setting of
> /usr/local, but not until *after* it has already been used to define
> INST_DIR).
> You should be able to just fix the INST_DIR setting in
> include/Make/Platform.make then re-run "make install".
