[GRASS-user] Re: [GRASS-dev] New Mac OS X application build option
Michael Barton michael.barton at asu.edu
Wed Mar 14 20:20:04 EDT 2007
Cheers to you and Glynn!
Michael
On 3/14/07 3:13 PM, "William Kyngesburye" <woklist at kyngchaos.com> wrote:
> Finally got the Mac OS X build option into CVS, with a little
> configure/makefile help from Glynn.
> To build GRASS as a Mac OS X application (exactly like my binaries,
> if anyone has used those), add these options to your configure command:
> --prefix=/Applications --enable-macosx-app
> Since the default prefix is /usr/local and it's nearly impossible to
> have multiple conditional default prefixes in configure, you should
> set the prefix as above.
> It's tested with OSX 10.4 and the latest Xcode.  It should work on
> 10.3, but it would be good to have verification of this if anyone
> cares to try it.
> Enjoy!
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> [Trillian]  What are you supposed to do WITH a maniacally depressed
> robot?
> [Marvin]  You think you have problems?  What are you supposed to do
> if you ARE a maniacally depressed robot?  No, don't try and answer,
> I'm 50,000 times more intelligent than you and even I don't know the
> answer...
> - HitchHiker's Guide to the Galaxy
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
