[GRASS-user] Re: grassuser Digest, Vol 11, Issue 18
    Hamish
    hamish_nospam at yahoo.com
    Fri Mar 16 00:43:21 EDT 2007
Maciej Sieczka wrote:
> I don't think you can import vector in standard format together with
> it's attributes using v.in.ascii. It's possible only for points
> format. In standard format, the "1982 2.88" etc. after x,y coordinates
> are discarded.
the form is one coordinate per line. Z value is optional.
 " X Y [Z]"
> To add attributes to your lines vector created with v.in.ascii, you
> would need to create the table separately (eg. a dbf with OO.org Calc
> or OO.org Base, or using the db.execute to create the table and
> populate it with values) and then attach it to your lines vector uisng
> v.db.connect.
> To understand how categories and layers work, please refer to the
> "Vector data processing in GRASS GIS" chapter of the manual.
see the v.in.garmin script for an example. (be it a slighlty complicated one)
Hamish
