[GRASS-user] gshhstograss.c
Brent Wood
b.wood at niwa.co.nz
Fri Mar 16 00:47:28 EDT 2007
> A much smarter man than myself explains:
> http://lists.maptools.org/pipermail/proj/2005-August/001710.html
> If you don't get an answer here, maybe ask on the PROJ.4 mailing list
> what an appropriate PROJ-compatible projection for the arctic would be.
For Antarctic data I normally use a Polar Sterographic projection, at
least with GMT. It doesn't generate maps with rectangular borders
though. Depending on what you are trying to do with the data, that or a
suitable Equidistant or Equal Area projection will work OK.
I'm assuming GRASS will work OK, as I use Proj4 & PostGIS to manage the
data for use with QGIS & GMT.
There is some info on this sort of thing at the NOAA NATICE website and
at the British Antarctice Survey (BAS) SCAR/ADD sites. The Antarctic
advice is just as useful at the other pole :-)
Googling for these acronyms will find the sites.
Cheers,
Brent Wood
