[Fwd: Re: [GRASS-user] Re: grassuser Digest, Vol 11, Issue 18]
Jorge Echeverri
jorge.echeverri at Stein.de
Fri Mar 16 07:15:39 EDT 2007
I had ask these questions to Maciek. For completeness I am sending them
again to the forum along with his answers and new questions:
I just imported:
> #'X_COORDINATE Y_COORDINATE'
> L 2 1
> 3400630.04 5718486.603 1982 2.88
> 3400639.238 5718515.776 1982 2.88
> 1 1
> L 2 1
> 3400639.238 5718515.776 1982 3.77
> 3400648.641 5718546.057 1982 3.77
> 1 182
> L 2 1
> 3400648.641 5718546.057 1982 4.7
> 3400665.041 5718562.99 1982 4.7
> 1 181
> both with and without -n and it worked in the same way.
> But now I have a question. This file contains not only coordinates but
> also 2 attributes: "Year" and "Depth" in the columns 3 and 4. If I
> follow the instructions of v.in.ascii manual:
> "The coordinates are listed following the initial line containing the
> primitive code, the total number of vectors in the series, and the
> number of categories (1 for a single layer, higher for multiple
layers).
> Below that 1 or several lines follow to indicate the layer number and
> the category number (ID)."
> I rewrite my file like:
> L 2 2
I don't think you can import vector in standard format together with
it's attributes using v.in.ascii. It's possible only for points format.
In standard format, the "1982 2.88" etc. after x,y coordinates are
discarded.
To add attributes to your lines vector created with v.in.ascii, you
would need to create the table separately (eg. a dbf with OO.org Calc
or OO.org Base, or using the db.execute to create the table and
populate it with values) and then attach it to your lines vector uisng
v.db.connect.
To understand how categories and layers work, please refer to the
"Vector data processing in GRASS GIS" chapter of the manual.
> 2 1
> L 2 2
> 1 182
> 2 182
> L 2 2
> 1 181
> 2 181
> The last 2 in the first line for the number of attributes, isn't it?
> And data are rightly imported:
> Erzeuge Topologie ...
> 3 primitives registriert
> Building areas: 100%
> 0 Flächen erstellt
> 0 Inselflächen erstellt
> Füge Inselflächen hinzu:
> Füge Zentroide hinzu: 100%
> Die Topologie wurde erstellt.
> Anzahl von Knoten : 4
> Anzahl von Primitives : 3
> Anzahl von Punkten : 0
> Anzahl von Linien : 3
> Anzahl von Boundaries : 0
> Anzahl von Zentroiden : 0
> Anzahl von Flächen : 0
> Anzahl von Inseln : 0
> But I have to admit, I'm still confused with the concept of layer and
> category in GRASS; i.e., I wrote these lines:
> 1 182
> 2 182
> Like first line1 for Layer 1 and 182 from original line ID of my data
> and second line
> and second line for Layer 2 and 182 from original line ID of my data
> was this right?
You propbaly mean this part:
> L 2 2
> 1 181
> 2 181
If you wanted the given line, consinsted of 2 vertices, to have 2
attribute links (categories), one in the layer 1 and the other in layer
2, both with category number "182", you did it right.
Oh, I think I misunderstood the concept of category:
Actually, what I want to do is to create layers 1 and 2 for each line
and that those have attribute values in the fields "Year" and "Depth" in
the table below:
L 2 2
1 181
2 181
Table:
LineID Year Depth
1 1982 2.88
182 1982 3.77
181 1982 4.7
So I guess, I have to import the line geometry like
L 2 1
1 2
2 3
L 2 1
1 2
2 3
L 2 1
1 2
2 3
Each line having layers 1 and 2 that connect to values in the categories
2 and 3.??
Or from the example in v.in.ascii manual is still not so clear what the
line below the data means???
ORGANIZATION: GRASS Development Team
DIGIT DATE: 1/9/2005
DIGIT NAME: -
MAP NAME: test
MAP DATE: 2005
MAP SCALE: 10000
OTHER INFO: Test polygons
ZONE: 0
MAP THRESH: 0.500000
VERTI:
B 6 1
5958812.48844435 3400828.84221011
5958957.29887089 3400877.11235229
5959021.65906046 3400930.7458436
5959048.47580612 3400973.65263665
5959069.92920264 3401032.64947709
1 1
B 4 1
5959010.9323622 3401338.36037757
5959096.7459483 3401370.54047235
5959091.38259917 3401450.99070932
1 2
Does it mean that the first boundary has the layer 1 related to the
category with number ID 1 and the second boundary has the layer 1
related to the category 2 with number ID? It doesn't make much sense.
and then use v.db.connect to assign the geometric entities with the
values in the table. But when I get through the v.db.connect manual is
not clear to me how records and fields on the table are correctly
assigned to the respective lines??
Jorge
> On the other hand how can I classify and visualise these data with
> GRASS?
d.vect, d.vect.thematic
Both available via gis.m and d.m as well as from command line. There is
also QGIS which has nice thematic mapping capabilities and reads GRASS
vectors.
P.S.
Please don't ask question offlist. It's better to let others
participate.
Cheers,
Maciek
Jorge Echeverri, BSc Civ. Eng.
S & P CONSULT GMBH
Technologiequartier
Konrad-Zuse-Str. 6
D-44801 Bochum, Germany
Geschäftsführer: Dipl.-Ing. Robert Stein
Registergericht: Amtsgericht Bochum HRB 10769
Phone: +49(0) 234 51 67 193
Fax: +49(0) 234 51 67 109
Email: jorge.echeverri at stein.de
Internet: www.stein.de
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070316/e619541d/attachment.html
