[GRASS-user] mfilter
Tue Mar 20 10:16:53 EDT 2007
Jaros-Bław Jasiewicz wrote:-A
> > I do wonder if mfilter can perfom filtering on float raster, ie
> > providing results as raster. My recent use of r.mfilter led me to
> > the contrary (i.e output is integer also input was raster). I am
> > wrong somewhere?
> well, not
> The only solution is to multipy orginal map before filtering, and divide
> it after
> but... it is possible to change the r.mfilter to output fp maps? Is I
> read source code the results is fp and next is rounded to near integer.
> Maybe removing this part will be enough (but I'm not sure, I'm not
> skilled enough in grass programming)
There isn't any fundamental reason why r.mfilter cannot be changed to
create FP maps.
Apart from allocating FCELL/DCELL buffers, certain functions need to
be changed, e.g.:
	G_open_cell_new -> G_open_fp_cell_new
	G_get_map_row -> G_get_d_raster_row
Also, the code would need to check for and handle null values; the old
G_get_map_row() interface silently converts nulls to zeroes.
