[GRASS-user] Adding a semi-transparent layer
Glynn Clements
glynn at gclements.plus.com
Thu Mar 22 10:18:54 EDT 2007
José Antonio Ruiz Arias wrote:
> I've been trying to create the PPM/PGM pair with the PNG driver. Using the next commands I get the ppm file:
> export GRASS_TRUECOLOR="TRUE"
> export GRASS_WIDTH=642
> export GRASS_WIDTH=371
> export GRASS_PNGFILE=mde.ppm
> d.mon start=PNG
> d.mon select=PNG
> d.rast map=mde
> d.mon stop=PNG
> But doing the same for the pgm file I get an error message. I have
> looked for some specific command in GRASS to create de pgm but I
> haven't found it.
Add:
export GRASS_TRANSPARENT=TRUE
This will cause a PGM file to be written out in addition to the PPM
file. The PGM file contains the mask.
> Also looked for the mapdisp.tcl to take it a look
> but I don't have it in my system (at least that's what I think).
The file which performs the compositing is etc/gm/mapcanvas.tcl.
