[GRASS-user] Still something wrong importing with v.in.ascii and connecting to DB
Jorge Echeverri jorge.echeverri at Stein.de
Thu Mar 22 10:54:54 EDT 2007
Regarding my question yesterday. I am again trying to depict the
attributes already mentioned:
1.I performed a MySQL-query on tbl_node and tbl_line to obtain the
couples of points defining a line and stored this in a .csv-file and
into a new table in my database, tbl_attributes. This table also
contains the attributes I need.
 tbl_attributes
"SECTION_ID","X_ANFANG","Y_ANFANG","X_ENDE","Y_ENDE","Baujahr","Laenge","Gebiet","MTiefe","KNutzung","Material","PArt","PBreite","PHoehe","ANALYSIS_CHAPTER"
1,3400630.04,5718486.603,3400639.238,5718515.776,1982,30.59,"Niederaden",2.88,1,"Beton",1,300,300,1
182,3400639.238,5718515.776,3400648.641,5718546.057,1982,31.71,"Niederaden",3.77,1,"Beton",1,300,300,1
2. I created a new file with an awk-programm:
L 2 11
3400630.04 5718486.603
3400639.238 5718515.776
1 1
6 6
7 7
8 8
9 9
10 10
11 11
12 12
13 13
14 14
15 15
L 2 11
3400648.641 5718546.057
1 1
6 6
7 7
8 8
9 9
10 10
11 11
12 12
13 13
14 14
15 15
Each line having a series of layers each associated to a category
number!? Is this right?
3. I could load these data with v.in.ascii into GRASS
4. And I also could connect this vector file with the tbl_attributes in
my DB
The problem is when I try to display the data. Using QGIS I realised
that the entire vector file takes the attributes from the first
record!!??? I tried the same with GRASS using d.vect.thematic and have
the same problem:(  What did I do wrong? I don't find out the answer.
Any ideas????
Thanks
Jorge
I need to do the following:
Display a sewer network and generate charts with classification in a
colour scale based on attributes like Age, Material, Diameter, etc.
Data are in a MySQL database:
The network is geometrically defined by the relationship between these
two tables:
tbl_line:
"LINE_ID","FROM_NODE_ID","TO_NODE_ID"
1,1,2
tbl_node
"NODE_ID","X_COORDINATE","Y_COORDINATE","Z_COORDINATE","NET_TYPE_ID"
1,3400630.04,5718486.603,,1,
Assuming that attributes where also stored in the same table: tbl_line,
which is not the case, how would be the better way to perform this task?
Attributes are actually stored in another table, tbl_basedata, which is
in the same database and has a 1:c relationship to tbl_line.
So far I have managed to connect to the MySQL-database but cannot figure
out how to further proceed.
Previously I had tried following workaround:
couples of points defining a line and stored this in a .csv-file.
2. From this I created a new file with an awk-programm like this:
#'X_COORDINATE, Y_COORDINATE'
L 2 0
L 2 0
L 2 0
3400665.041 5718562.99
L 2 0
3400625.996 5718597.349
L 2 0
3.I successfully imported this with v.in.ascii and can depict the
geometry.
But I don't think that is the most logical way to do it as GRASS can
connect directly to the DB. Any suggestions???
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070322/b24bb05c/attachment.html
