[GRASS-user] Maximum number of GRASS files within a mapset?
Paul Kelly paul-grass at stjohnspoint.co.uk
Fri Mar 23 19:13:48 EDT 2007
On Fri, 23 Mar 2007, Shaun Walbridge wrote:
> Hi,
> I seem to be running into a GRASS limitation relating to the maximum number
> of rasters available within a single mapset location, which appears to be
> exactly 32000.  Attempting to create additional rasters generates the
> message:
> ERROR: can't make mapset element cell_misc/test00
> which seems to be coming from lib/gis/mapset_msc.c:
>  if (access (path, 0) != 0)
>  G_fatal_error (_("can't make mapset element %s (%s)"), p_element, path);
> Is there any way of circumventing this limitation, or is it a hardcoded C
> limitation?
I fear it may be a Unix limitation - the maximum number of files in one
directory. Maybe reading documentation to see if there was anyway to
increase this would be the best course of action.
Paul
