[GRASS-user] Learning to use vector layers
Daniel Victoria
daniel.victoria at gmail.com
Mon Mar 26 13:23:22 EDT 2007
Hi Jaime,
No, all data, for all stations and all months/days are in one big
table! I guess I'll just keep changing the network connection for now.
Cheers
Daniel
On 3/26/07, Jaime Carrera <jaicarrerahdez at yahoo.com> wrote:
> Hi Daniel,
> Well, it depends on your database structure. If you have one table for each
> month:
> SELECT t1.id, t1.east, t1.north, t1.rain,t2.rain,t3.rain FROM table1 as t1,
> table2 as t2, table3 as t3 WHERE...
> Jaime
> ----- Mensaje original ----
> De: Daniel Victoria <daniel.victoria at gmail.com>
> Para: Jaime Carrera <jaicarrerahdez at yahoo.com>
> CC: grass <grassuser at grass.itc.it>
> Enviado: lunes, 26 de marzo, 2007 16:36:23
> Asunto: Re: [GRASS-user] Learning to use vector layers
> Yea, that could do it also, just have to figure out how to perform
> different queries for each column so I'd have average January on col
> 1 and avg February on two and so on. Probably a bunch of table
> updates?
> Thanks
> Daniel
> > Hi Daniel,
> > You could also generate a table like this:
> > id|easting|northing|9001|9002|9003|...|9012|9101|...
> > Then you have your data in one table which can be
> > linked to the vector file. Such a table can be
> > generated from other tables using SQL commands.
> > HTH
> > Jaime
> > --- Daniel Victoria <daniel.victoria at gmail.com>
> > escribió:
> > > Hi all,
> > > I have a vector problem and I think it might be a
> > > job for vector layers.
> > > I have a postgresql table with daily meteorological
> > > station data (~10
> > > years, 300 stations) and I'd like to get average
> > > monthly precipitation
> > > for each station.
> > > That I can easily do with a SQL query, generating a
> > > view and attaching
> > > the view to a vector file where the CAT column is
> > > the station number.
> > > The problem is, I can only attach one SQL view at a
> > > time since the
> > > vector file has only one category (from what I read,
> > > it's one category
> > > per layer connection correct?)
> > > So, I though about some options:
> > > 1) either generate 1 vector file for each month -
> > > simple but then I
> > > don't learn about layers
> > > 2) keep changing the database connection for each
> > > month - works but
> > > seems kind of improvisation
> > > 3) Use layers, one layer for each month. I'd have
> > > the advantage of not
> > > having categories for stations with no data for a
> > > specific month for
> > > example and also, I'd learn about layers
> > > So, the proper questions:
> > > Does this sounds like a job for vector layers?
> > > How do I add categories to a vector file but, the
> > > categories should
> > > come from a column in a SQL view? From what I read,
> > > v.category can
> > > only add sequential cats and I'd like the cats to be
> > > the station
> > > number.
> > > Cheers and sorry for the long email
> > > Daniel
> > > _______________________________________________
> > > grassuser mailing list
> > > http://grass.itc.it/mailman/listinfo/grassuser
> > __________________________________________________
> > Correo Yahoo!
> > Espacio para todos tus mensajes, antivirus y antispam ¡gratis!
> > Regístrate ya - http://correo.espanol.yahoo.com/
> Correo Yahoo!
