[GRASS-user] problem with v.edit tool=merge
Jarek Jasiewicz
jarekj at amu.edu.pl
Tue Mar 27 15:38:56 EDT 2007
Martin Landa napisał(a):
> Hi,
> could be possible to reproduce this vector data?
> Martin
> 2007/3/27, Jaros�aw Jasiewicz <jarekj at amu.edu.pl>:
>> Hi
>> I tired:
>> v.edit map=linie layer=1 type=line tool=merge thresh=0 cats=14,15
>> and I recived:
>> GRASS_INFO_MESSAGE(6432,1): [2] of [17] features selected
>> GRASS_INFO_MESSAGE(6432,2): [0] features merged
>> GRASS_INFO_MESSAGE(6432,3): v.edit complete.
>> I also tried with no treshold parameter. Result is the same
>> but If I use tool=snap all is ok,lines are snapped (but I ecxpect merge,
>> not only snap)
>> do I something wrong?
>> I add it is very simple vector file with few lines, crated to experiment
>> with that new fascinating tool
>> Jarek
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
thanks for ansver
but how to reproduce???
I just simply draw (v.digit) few lines (with categories but without
table) in new vector.
Lines look like ---1-- ---2---- ---3---, every line has own cat
now I try:
v.edit map=linie layer=1 type=line tool=merge thresh=0 cats=1,2
GRASS_INFO_MESSAGE(6432,1): [2] of [3] features selected
and green bar stops at half...
if I try similar tool:
v.edit map=linie layer=1 type=line tool=snap thresh=0 cats=1,2
all goes OK i.e lines are snapped
I tried it on few files and few machines everywhere it gos the same
I add, I need that tool. I prepared useful scrpit (for now it works with
snap option only) which (will be) based
on that tool. So I need to understand If there is problem with tool and
I shall look for another solution (or wait) or I do something wrong
regards
Jarek
