[GRASS-user] problem with v.edit tool=merge
    Jarosław Jasiewicz
    jarekj at amu.edu.pl
    Wed Mar 28 03:32:53 EDT 2007
Martin Landa napisał(a):
> Hi,
> BTW it seems you are not using the fresh CVS installation. Tool for
> merging in v.edit has been modified recently [date: 2007/03/25
> 10:41:55].
> Regards, Martin
> 2007/3/27, Jarek Jasiewicz <jarekj at amu.edu.pl>:
>> > Hi,
>> > could be possible to reproduce this vector data?
>> > Martin
>> > 2007/3/27, Jaros�aw Jasiewicz <jarekj at amu.edu.pl>:
>> >> Hi
>> >> I tired:
>> >> v.edit map=linie layer=1 type=line tool=merge thresh=0 cats=14,15
>> >> and I recived:
>> >> GRASS_INFO_MESSAGE(6432,1): [2] of [17] features selected
>> >> GRASS_INFO_MESSAGE(6432,2): [0] features merged
>> >> GRASS_INFO_MESSAGE(6432,3): v.edit complete.
>> >> I also tried with no treshold parameter. Result is the same
>> >> but If I use tool=snap all is ok,lines are snapped (but I ecxpect
>> merge,
>> >> not only snap)
>> >> do I something wrong?
>> >> I add it is very simple vector file with few lines, crated to
>> experiment
>> >> with that new fascinating tool
>> >> Jarek
>> >> _______________________________________________
>> >> grassuser mailing list
>> >> grassuser at grass.itc.it
>> >> http://grass.itc.it/mailman/listinfo/grassuser
>> thanks for ansver
>> but how to reproduce???
>> I just simply draw (v.digit) few lines (with categories but without
>> table) in new vector.
>> Lines look like ---1--  ---2----  ---3---, every line has own cat
>> now I try:
>> v.edit map=linie layer=1 type=line tool=merge thresh=0 cats=1,2
>> GRASS_INFO_MESSAGE(6432,1): [2] of [3] features selected
>> and green bar stops at half...
>> if I try similar tool:
>> v.edit map=linie layer=1 type=line tool=snap thresh=0 cats=1,2
>> all goes OK i.e lines are snapped
>> I tried it on few files and few machines everywhere it gos the same
>> I add, I need that tool. I prepared useful scrpit (for now it works with
>> snap option only) which (will be) based
>> on that tool. So I need to understand If there is problem with tool and
>> I shall look for another solution (or wait) or I do something wrong
>> regards
>> Jarek
Hi
it is fresh instalation. in previous instalation v.edtit wasn't
avaliaible by default
Jarek
