[GRASS-user] problem with v.edit tool=merge
Jarosław Jasiewicz
jarekj at amu.edu.pl
Wed Mar 28 08:30:22 EDT 2007
> Because I cannot tell you why the lines are not merged (or fix a bug).
> Without any testing data I can do nothing. v.out.ascii format=standard
> exports a vector map into GRASS ASCII-vector format. Then I can import
> it, reproduce a strange behaviour of module and fix it.
thanks, here are linie.txt with exported data. It is simple testing file.
I also can send the binary vector file (zipped directory) if you wish
regards
Jarek
ORGANIZATION:
DIGIT DATE:
DIGIT NAME:
MAP NAME:
MAP DATE:
MAP SCALE: 1
OTHER INFO:
ZONE: 0
MAP THRESH: 0.000000
VERTI:
L 6 1
381864.87117803 385450.44349761
383136.04125283 383805.39987141
383435.14009396 382459.45508633
384033.33777622 380664.86203956
384481.98603791 379618.01609561
384781.08487904 378720.71957222
1 26
L 5 1
353226.15713997 374907.20934783
354721.65134561 374832.43463755
359507.23280367 374383.78637585
363245.96831778 375654.95645065
364965.78665427 376327.92884319
1 27
L 6 1
366760.37970104 375355.85760952
366909.9291216 374682.88521698
367657.67622442 373336.9404319
372293.70826192 372888.29217021
373490.10362643 373187.39101134
374536.94957038 373187.39101134
1 28
L 6 1
371471.18644881 391432.42032019
372817.13123389 390983.77205849
373415.32891615 390834.22263793
375808.11964518 391507.19503047
379023.43218731 392479.26626414
379771.17929013 398087.3695353
1 23
L 5 1
343804.54364441 391208.09618934
347618.05386881 392329.71684357
348963.99865388 390983.77205849
351805.43764461 390535.1237968
360479.30403734 390684.67321737
1 21
L 6 1
362049.57295326 383880.17458169
366685.60499076 382758.55392746
368181.0991964 382609.00450689
372218.93355163 384852.24581536
373863.97717784 384702.69639479
376256.76790687 383805.39987141
1 25
L 5 1
362273.89708411 390908.99734821
363171.19360749 391058.54676878
364068.49013088 390460.34908652
366760.37970104 390834.22263793
1 22
L 5 1
346346.88379401 383132.42747887
352179.31119602 384104.49871254
354347.7777942 382758.55392746
357862.18917746 382609.00450689
359058.58454198 383655.85045084
1 24
L 4 1
343580.21951357 399134.21547925
346197.33437344 399807.18787179
349636.97104642 398162.14424558
351356.78938291 399283.76489981
1 18
L 7 1
368554.97274781 398835.11663812
373564.87833671 399881.96258207
375509.02080405 399508.08903066
376929.74029941 398461.24308671
378500.00921534 398685.56721756
379397.30573872 398461.24308671
1 20
L 6 1
353899.12953251 399134.21547925
359208.13396254 396442.32590909
362498.22121495 397713.49598389
364816.2372337 399508.08903066
367433.35209358 398536.01779699
367508.12680386 397638.72127361
1 19
