[GRASS-user] bash scripts and NLS
Glynn Clements
glynn at gclements.plus.com
Wed Mar 28 17:35:12 EDT 2007
Hamish wrote:
> > > ...d.what.vect -1 -t map=lines|grep category|awk '{print $2}'>>cat.txt...
> > > I compiled grass with NLS (national languages suports) and script
> > > stop working becouse there is no category (grep) but kategoria
> > > (category in polish). In my few scripts it is no problem (or rather
> > > I will never use NLS), but what about scripts in grass add-ons and
> > > nls?
> Glynn:
> > If a script parses output which is meant to be human-readable, it
> > needs to explicitly set the locale to "C" for that command, e.g.:
> > LC_ALL=C d.what.vect -1 -t ...
> d.what.vect's -t specifically says it is for parsing:
> -t Terse output. For parsing by programs
Ah. Either the description is wrong, or the use of _(...) is a bug.
> the i18n is not new, it's been there for 2.3 years. (but maybe the
> translation is)
> so a question: should std output intended for parsing be strictly
> english only? (as debug messages are)
If it's meant to be machine-readable, it shouldn't depend upon the
locale in any way.
> e.g. north: south: etc by g.region -p (not talking about g.region -g)
> [-p is currently not translated]
I would say that -p output should be human-readable (if it isn't, then
how do you view the current region settings in a human-readable
form?).
Having said that, it wouldn't surprise me if there are a lot of
scripts which parse "g.region -p" output, so we would first need to
fix those to use -g instead.
