[GRASS-user] Making vector layers accessibla for different
projects
Rainer M. Krug
rmk at krugs.de
Thu Mar 29 07:55:28 EDT 2007
Hi Jachym
Jachym Cepicky wrote:
> Hi,
> if "project" and "location" are equivalent for you, than no, this is
> not possible.
Yes, they are. But you are right - I should have said location.
> You can copy files from one location to another using r/v.proj modules
Thanks a lot - this helps.
> you can access maps stored in different mapset. g.mapsets is your
> friend then
I found that one - and I am going to use it as well.
Thanks a lot,
Rainer
> j
> 2007/3/29, Rainer M. Krug <rmk at krugs.de>:
>> Hi
>> This might be a stupid question - but is there an easy way of making
>> vector layers available in different projects? And if not, how can I
>> copy them between different projects?
>> I am using Linux, so links might be an option?
>> Thanks
>> Rainer
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
