[GRASS-user] Error updating GRASS
Fri Mar 30 05:19:24 EDT 2007
Michael Barton wrote:
> This is probably due to a problem with your gdal installation (there is a
> more informative error trapping in 6.3). Try g.region -p and see what you
> get.
No, this error is quite definitely a result of invalid Tcl. The
argument to "global" must be the name of either a scalar variable or
an array variable; you can't use individual array elements.
