[GRASS-user] Error updating GRASS
António G Rodrigues
agrodrigues at ipt.pt
Fri Mar 30 05:45:06 EDT 2007
I followed the threads below and the problem is solved by changing in
mapcanvas.tcl the line:
global coords($mon) to global coords.
Thanks to everyone that helped with this...
António
Glynn Clements wrote:
> Jachym Cepicky wrote:
>>> I apdated to grass6.2 in my ubuntu system using the repositories in...
>>> deb http://les-ejk.cz/ubuntu edgy multiverse
>>> deb-src http://les-ejk.cz/ubuntu edgy multiverse
>>> The problem is that when opening grass it crashes everytime. The error message is:
>>> GRASS 6.2.1 (Europe):~ > Error in startup script: bad variable name "coords(1)": upvar won't create a scalar variable that looks like an array element
>>> while executing
>>> "global coords($mon)"
>>> (procedure "MapCanvas::pointer" line 5)
>>> invoked from within
>>> "MapCanvas::pointer $mon"
>>> (procedure "MapCanvas::create" line 226)
>>> invoked from within
>>> "MapCanvas::create"
>>> (procedure "Gm::startmon" line 11)
>>> invoked from within
>>> "Gm::startmon"
>>> (procedure "Gm::create" line 69)
>>> invoked from within
>>> "Gm::create"
>>> (procedure "main" line 30)
>>> invoked from within
>>> "main $argc $argv"
>>> (file "/usr/lib/grass/etc/gm/gm.tcl" line 521)
>>> Any clues?
>> hi, nobody else reported such problem...
> Yes they did:
> http://grass.itc.it/pipermail/grassuser/2007-March/038688.html
> http://grass.itc.it/pipermail/grassuser/2007-March/038689.html
> This is fixed in CVS.
