[GRASS-user] ...|no data problem
Martin Wegmann wegmann at biozentrum.uni-wuerzburg.de
Wed May 2 08:23:01 EDT 2007
Hello,
I think it is a very simple problem but I don't get it.
I have a raster which I want to convert to integer but doing so results in
areas with null() values.
When I look at the input raster (r.what) I get areas which look like this:
-1.59582443346|6.02450629749||927119811.912364006|
which also look fine in the integer conversion, but other areas give following
r.what infos:
-2.14304204004|6.63535385832||2633784216.1745109558|no data
these areas results in null() values after integer conversion.
I tried to remove the |no data part with the @rastername in r.mapcalc but that
does not work, because only the second part is taken.
Any ideas how to remove the |no data part?
TIA, Martin
